How many of your are running SD all the time?
Old 04-15-2008, 02:05 AM
maxgee's Avatar
Default How many of your are running SD all the time?
Post your input with running SD all the time, please.
I'm considering this, but live in FL where we have high humidity in the summer. I'm working on my tune now, high humidity hasn't hit us yet...suggestions?
Old 04-15-2008, 02:52 AM
ninetres's Avatar
I am......even though my car is never up for a long period of time
Just have your tuner tweak it for changes in season.
Old 04-15-2008, 08:07 AM
Websy21's Avatar
I am not there yet but I'll be running a SD tune all the time. From my understanding, if you have a good tune you won't have to tweak for temp changes unless you are after that 1-2% spot on tune. This is what the IAT sensor is for. I am not tuning my car so I hope I am right, it will be a one time deal once everything is broken in.
Old 04-15-2008, 08:30 AM
LS1Tech Sponsor
hellbents10's Avatar
Just depends on how good the tune is. There is correction tables for baro, etc, and iat. So weather changes shouldn't throw you off far enough to ever warrant a necessary tune change.
Old 04-15-2008, 08:32 AM
Websy21's Avatar
Thats what I got out of the tuning section, I won't know how to do this but I'll make sure my tuner does
Old 04-15-2008, 11:10 AM
Z06PSI's Avatar
Full time SD here with no problems. Tuner is below.
Old 04-15-2008, 11:38 AM
Schantin's Avatar
Yep, been in SD mode for a while and 2-bar SD for the past 4 months. Driven the car 2x from Virginia to Alabama with outside temps ranging from 20-80 degrees. Have not needed to change the basic tune. The MAP sensor notes pressure, so that takes care of altitude changes. The IAT is measuring the intake temp, so that covers the differences in outside air temp too.
BTW, for FI I highly recommend the 2-bar SD mode of operation. It makes for smooth power increase cause you can tailor the VE table for part-boost cells. On the dyno the HP/torque curve looks more like a N/A car than a FI car. No sudden hp/torque spikes or oscillations that are the norm in 1-bar SD or MAF modes.
Old 04-15-2008, 12:32 PM
kbracing96's Avatar
I've been running my truck in 2bar SD for the last 2 years. Everything from WY winters to AZ summers.
Old 04-15-2008, 12:56 PM
Z06PSI's Avatar
I am 2-bar as well but getting ready for 3 bar.
Old 04-15-2008, 03:16 PM
frcefed98's Avatar
2 bar SD here
Old 04-15-2008, 03:21 PM
Dynojet Fan
VH5150's Avatar
Ive noticed that if the car is tuned at a certain IAT, depending if the IAT goes up or down will determin if the car runs lean or rich @ WOT.At least on my car anyways...
Old 04-15-2008, 05:03 PM
Anti-Vnm's Avatar
I'm not boosted, but I've been running SD in my DD for over 3 years.
Old 04-15-2008, 08:43 PM
koji777's Avatar
3 bar here
Old 04-15-2008, 08:46 PM
LS1Tech Sponsor
Slowhawk's Avatar
Have had 4 cars SD tuned for years including my wifes turbo truck. Haven't touched them since they were done and if they went way off we'd know because the motors would be blown.Tuned about a dozen more this year in OLSD with no problems as of yet.
Old 04-15-2008, 08:50 PM
maxgee's Avatar
My 93 LT1 Camaro was speed density.
My bike has no closed loop operation either, no o2s so I assume is a speed density set up? I have tuning software and hardware for it also "powercommander" affliated with Dynojet. I've taken it from Florida 90+ degree weather at sea level to GA 50 degree weather over 3,000 feet above sea level with no problems. So I'm assuming our cars with SD should be fine if the tune is done correctly. Thanks for your replies.
Old 04-15-2008, 09:15 PM
NYSS Guy's Avatar
I've been running a 2 bar SD for a couple of years now....and I'm in S. Fla too. I haven't had any issues, but I do keep an eye on things with HP Tuners. Where are you?
Old 04-16-2008, 12:32 PM
maxgee's Avatar
Homestead Florida
You sig says you are running out of fuel with your Racetronix pump.
Another LS1 M6 guy up in Boca says his Racetronix pump wasn't enough either, but guys I talked to with Walbros pushing forced induction say they are good with one Walbro up to 600hp. I'm wondering if Racetronix pump is an issue.
Anyway, I would like to meet up and check out your set up. I just got mine installed a couple weeks ago and still need to finishing tuning. I'm waiting on two pins to run my wideband to my EGR plugs in the ECU.
my email is maxg929@gmail.com
Old 04-16-2008, 01:07 PM
Rickys S/C Z28's Avatar
im getting mine done in SD then ill let you know
Old 04-16-2008, 01:09 PM
SPRAYED 01's Avatar
Im running sd tune all the time. My racetronix would not hold. I had to swap it out for the lonnies dual intank.
Old 04-16-2008, 01:32 PM
52172's Avatar
full time SD here Ken from HP tuners tuned mine 2Bar.
