ls7 clutch part number?
Old 04-15-2008, 02:10 PM
z28killz's Avatar
Question ls7 clutch part number?
hey guys quick question... is this the ls7 clutch kit part number?
M6 stock replacement LS6 clutch kit (flywheel, clutch, pressure plate) (from Z06) = 12570806
my clutch just went so i need to replace and i want to get the ls7 kit.
Old 04-15-2008, 06:39 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Here ya go
http://www.sdparts.com/product/SDLS7...cFlywheel.aspx
Old 04-17-2008, 11:49 AM
JasonWW's Avatar
That's the older LS1 kit.
These are the part numbers for:
LS2 flywheel: 12571611
LS7 Clutch: 24238412
Old 09-19-2008, 01:54 AM
darknessxyz's Avatar
I've to dig it out from the grave for some questions. I've a 02 Formula M6 and I guess it's still using the oem clutch. Here's the question
1) Can I use the complete LS7 clutch kit (the one at sdparts.com) in my LS1?
2) If no, then I've to go LS2 flywheel and LS7 clutch. But what kinda pressure plate I should use?
Old 09-19-2008, 02:08 AM
onefastrx7turbo's Avatar
Hey dark, I just bought a brand new in box LS7 clutch kit and Ls2 flywheel on ebay for $322 shipped!!! im using a t56 and an L92
Old 09-19-2008, 02:38 AM
Damn man, that's a killer deal. I think it's time for me to dig in the bay. So are you using the LS7 pressure plate?
Old 09-19-2008, 06:49 AM
Hugger Z's Avatar
LS7 pressure plate comes with the clutch kit. And the LS2 flywheel is the same at the one that comes wtih the LS7 clutch. I bought my LS7 clutch off of someone that took it off their crate motor. It all bolted right up to my car. Been running strong since last spring and is surviving the turbo's with no problems.
Old 09-19-2008, 09:27 AM
PewterMNZ's Avatar
Yes and the ls2/ls7 flywheel are the same thing.
Old 09-19-2008, 12:26 PM
So you guys are using LS7 pressure plate?
Then basically I can use the whole LS7 clutch kit to install in my LS1.
Old 09-19-2008, 12:35 PM
Z28/2002's Avatar
Yes get the kit from SDPC
Old 09-20-2008, 05:30 AM
Does it looks real to you guys?
http://cgi.ebay.com/ebaymotors/ws/eB...m=140268721071
Old 09-21-2008, 12:05 PM
Anyone?
Old 09-22-2008, 03:06 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Our kit will work fine for you, just give me a call.
-Jesse
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 11-12-2008, 12:34 PM
Engine_HP's Avatar
searched in www.gmpartsdirect.com
there was no part found for part number 24238412.
the flywheel part number was fine
thanks
Old 11-12-2008, 02:12 PM
Part numbers have changed
__________________
Old 11-12-2008, 02:42 PM
Engine_HP's Avatar
then whats the new P/N ?
thanks
Old 11-12-2008, 03:33 PM
coderedDVSS8TR's Avatar
that part number worked for me...
Old 11-12-2008, 03:52 PM
The new number comes up in their system if you put in the old one. It's still cheaper through us, as they add on $82 shipping and with ours you get all new bolts with it.
__________________
Old 11-12-2008, 03:55 PM
Aetos's Avatar
My LS7 kit from you guys just arrived at my house. Everything looks good! Flywheel, pressure plate, clutch, and 12 bolts all included. Can't wait to get this thing installed!
Old 11-12-2008, 03:56 PM
Engine_HP's Avatar
its not for me
Quick Reply: ls7 clutch part number?
