help, rotor won't come off
Old 04-15-2008, 06:52 PM
Shooter_Jay's Avatar
Default help, rotor won't come off
Ok, what's the trick here? My rotor doesn't want to come off. Hitting it with a rubber mallet not doing much good as far as I can see. What's the trick? Caliper off, rotor wont move, please advise...
Old 04-15-2008, 07:05 PM
KILLER-LS1's Avatar
make sure you pulled off the little star washer that is around one of the wheel studs. just rip it off with pliers or dikes. you dont need to put it back on...
Old 04-15-2008, 07:07 PM
hmm don't remember seeing that, but I'll check. sounds obvious though. it is supposed to come right off right? was youirs stuck?
Old 04-15-2008, 07:10 PM
94'BLKBRD's Avatar
Some rotors are stuck with the rust or dirt......just keep hitting it from behind.Is it the front or rear?
Old 04-15-2008, 07:12 PM
Slvr00Bird's Avatar
BFH mod..
Old 04-15-2008, 07:18 PM
rear....
yeah bfh is very tempting. first tried a rubber mallet. Then actually just doing it with my mini sledge and a 2x6 in between. damn brake dust I don't like though, dangerous stuff. But anyway, doesn't seem to be budging. I think maybe hitting it directly with the full size sledge might do it, but more likely to warp it on even worse though and hate to put that side load on my rear end too. Oh also put some pb in there. Maybe more pb. I don't know. Please anybody know the trick take the time to let me in on the secret Oh and by the way, it's tough to get any kind of swing with the hammers without laying under the car and eating all that asbestos dust. Glad I'll be switching to ceramic this time for the future.
Old 04-15-2008, 07:21 PM
jRaskell's Avatar
Rear rotor? You don't have the e-brake on, do you?
94'BLKBRD's Avatar
parking/emergency brake up or down?
Old 04-15-2008, 07:23 PM
Danger731's Avatar
It takes time , patience, WD 40, AND most important - continue in a circle , don't hit the same spot more than twice in a row. I should have counted but I must have hit mine 40 or 50 times to get it to just barely move.
Old 04-15-2008, 07:33 PM
Thanks for the help guys, went with my big sledge , with a wood block and plenty of pb penetrant, whacked one side, turned 180 deg. whacked the other side and bingo. Thanks again guys. And yes had the ebrake off
Old 04-15-2008, 10:33 PM
Funny, the driver side one practially jumped off and attacked me when I got the sledge close to it...
BTW, night and day difference now with the new rotors. I should have done it long ago!
Old 04-15-2008, 10:36 PM
Luna's Avatar
Sometimes a big *** hammer is all it takes. When I did new rotors on my escort I completely destroyed the rotors (actually cracked them in several places) hitting them with the sledge.
Those things didn't want to budge.
Old 04-15-2008, 10:39 PM
yeah I remember once on my dakota they were so rusted on, I had the tire off, bunch of times in a row I jacked it up and dropped it on the rotor and it still wouldn't budge lol.
sweet look with those wheels btw Luna. Is that a chrome/polished lip or just reflection? Not usually a fan of black wheels without the contrast lip, but that's a great pic. Though of course somehow black makes a lot of cars look much better to me
Old 04-16-2008, 08:40 AM
Save the manuals!
wssix99's Avatar
A "Kinder and Gentler" way is to take a 2X4 or 2X6, place it across the studs and then use two C-Clamps to pull on each back side of the rotor. If you slowly tighten both sides, and use a little penetrating lubricant, it will "pop" off. Its a little more involved than using a hammer, but it does cut down on flying rotors.
Old 04-16-2008, 09:55 AM
NOBR8KSS's Avatar
You really don't have to go after it with a hammer. All you need is a couple of bolts to thread into the rotor...tighten them down with a ratchet and the rotor will pop off...very easy and no damage to the rotor.
All rotors have the threaded screw holes located in between the openings for the lugs.
Old 04-16-2008, 04:55 PM
NOW you guys tell me thanks though, I'll try to remember in the future.
Quick Reply: help, rotor won't come off
