Coolant leak
Coolant leak
It's coming from the bottom drivers side corner. It's not the radiator itself, but it's the little rubber boot with a screw clamp holding it on. Looks like it's a little cut in the boot itself. It only really leaks when I'm parked on a hill leaning backward. And it leaks quite a bit like that. It doesn't leak when my car is running, or when it's facing down a hill. Any one know where I can get a replacement boot, or if there's actually supposed to be something else in that spot? Because part of me thinks that isn't exactly the OEM part.
