Shavings in oil filter.
Old 04-16-2008, 01:27 PM
97BBlackZ's Avatar
Default Shavings in oil filter.
How much shaving in an oil filter is ok? or normal.
Its an lt1 the oil pressure looked fine. But i cut open the filter and inspected it. There are quite a few shinny fragments that are on every crease in the filter normally near the top or bottom edges.
Old 04-16-2008, 01:28 PM
stangkiller2005's Avatar
has any work been done to the car recently? for example a cam?
Old 04-16-2008, 01:44 PM
97BBlackZ's Avatar
nope. not since i first got it.. about 1-2 years ago
Old 04-16-2008, 03:12 PM
Jakes Dad's Avatar
Thats not natural is it? The plus side is the filter is doing it's job but. To prove if the filter is doing it's job pull the oil pan. Does this car set for long periods of time?
Jakes Dad
p.s. An engine self distructing is hard to identify. Surely if you sold the car or traded it, to those dealers you can't trust, you would inform the person or dealer what you recently found, right?
Old 04-16-2008, 03:30 PM
97BBlackZ's Avatar
Jakes Dad
No it set for a day before my car starting making a noise.
and what does the 2nd half have to do with this thread?
Old 04-16-2008, 08:28 PM
WS-6Will's Avatar
What did you use to cut the filter?
Old 04-17-2008, 12:20 AM
97BBlackZ's Avatar
Sheet metal clippers. Just pocketed a hole in it with a screw driver then basically cut it in pieces till i got filter out. Shouldn't have caused metal shavings in thats what your thinking.
Old 04-17-2008, 06:36 AM
WS-6Will's Avatar
My buddy has a cool tool that works like a big tubing cutter. Nice setup.
Quick Reply: Shavings in oil filter.
