Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
HOW to connect the PCV?
Old 04-16-2008, 03:38 PM
James911's Avatar
Default HOW to connect the PCV?
Hi,
where do I have to connect the PCV, and what is it for?
I read, that I have to connect to PCV port of my EDE 1406 to a PCV valve in the valve cover.
But in my valve cover is something which has no connection for a rubber. Is this a PCV valve?
If yes where do I have to vonnect my PCV port? Or do I need a new valve?
What is the sense of the valve? When I have preasure in my valve cover, to release it into the carb? If yes ist a filter after the valve not enough? CanI plug the PCV port?
An other question:
Do I have to connect the manifold vacuum directly to my HEI?
Do I have to connect the timed vacuum? (My car has no emission control)
James
Old 04-16-2008, 03:45 PM
bluebeast's Avatar
just plug it off and put a baffle in the valve cover to release the pressure from the top of the cylinder head...... i think its just used to warm up the air to get the car up to running temp but i dont know many people that run it
