General LSX Automobile Discussion - Head lights out
w06gto
04-17-2008, 02:19 PM
My car had some angle eye lights on it before so i bought some used oem ones and now the lowbeams dont work only the high beams work i searched but didnt find a similar problem i have checked the fuses it a 99 z28 btw
thanks
frank
Texfinn
04-17-2008, 02:21 PM
I'm sure you probably have done this already, but since you didn't mention it: Have you changed the bulbs? Just to make sure, you know... ;)
20SS07
04-17-2008, 02:26 PM
Wait, so you DON'T have the angel eyes in anymore? Correct? Because sometimes some of those aren't wired properly. But if you now have stock lights in that wouldn't be the issue.
w06gto
04-17-2008, 02:30 PM
yea i have 2 sets of halogens and 1 set of hids and none work so im stuck and there not angel eyes (its not a v6 but the previous owner thought it was)
98FreakZ
check your grounds on the core support for the headlights, had a similer problem to this on my 98 Z and one ground wire was barely hanging on
w06gto
04-17-2008, 03:09 PM
thanks for all the help guys i figured it out the wires were switched on the connector that goes the the bulb some ricer just messed with the wiring thats all easy fix
BadGTho
04-17-2008, 03:21 PM
get a test light... check grounds.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
