Reverse lockout solenoid circuit questions
Trying to figure out a few things here. Does anybody know how much current the reverse lockout solenoid draws? Does the PCM sink ground to enable the solenoid? Where does the power wire come from for the solenoid?
Thanks,
Nic
Thanks,
Nic
I believe when the solenoid is not energized it blocks reverse.
The pcm sends the signal to enable the use of reverse.
With key off I believe it is very VERY hard to put into reverse but not impossible.
