Lound bang at Idle and low rpm
Old 04-17-2008, 04:10 PM
StangSlayerSS's Avatar
Default Lound bang at Idle and low rpm (updated post #9)
Nosie is a loud banging at idle or low rpm! Seems to stop or atleast quite down at higer rpms. Sounds real bad is it a rod or bearing?
Old 04-17-2008, 04:45 PM
ss.slp.ls1's Avatar
Doesn't sound good.
Spun bearing or rod knock will usually trace rpms/acceleration.
Old 04-17-2008, 04:56 PM
DaddySS's Avatar
When did it start, how's the oil pressure, etc.
Old 04-17-2008, 05:51 PM
sweet-94z28's Avatar
Pull the belts off and see if it goes away.
Old 04-17-2008, 05:55 PM
cablebandit's Avatar
wonder if its cracked flywheel....oil pressure?
Old 04-17-2008, 08:43 PM
oil pressure was fine, did not over heat! Clutch and flywheel are brand new 200miles on them. Well ill start pulling it apart this weekend.
Old 04-17-2008, 11:08 PM
RoDan's Avatar
200 miles on the clutch? hmm...coincidence? who installed the clutch?
Old 04-18-2008, 04:20 PM
I did! I highly doubt it was the cluth but maybe! sounded like someone was hitting the block with a hammer! But ill find out soon.
Old 04-24-2008, 09:11 PM
well appears I had a brand new ls7 lifter break causing valve to tag piston!
Old 04-24-2008, 11:34 PM
bayer-z28's Avatar
Ouch.. damn it all!! All there is to do now it to pull the heads and inspect..
