Single Digit Club - suspension set up
ssfast99
04-17-2008, 05:55 PM
what are you guys using for the rear setup on a torque arm car. my springs are my main concern along with sway bar. cant do a drag bar because stupid me had the 9" powder coated already.
myws6istheshiznit
04-17-2008, 10:25 PM
im using all spohn suspension and im getting a spohn drag bar as soon as my buddy pays me for some parts!
ssfast99
04-18-2008, 11:51 AM
are you following me, ill pay you later.
fastlane02
04-18-2008, 08:09 PM
you can still put the drag bar on. just dont weld it.
I'm running all spohn stuff under my car with 12 bolt
tektrans
04-19-2008, 04:40 PM
I use dual rear airbags to stiffen up the rear. If you're concerned about your springs you may want to try them.
I also use the Spohn dragbar.
rtk434
04-20-2008, 05:22 PM
I run the spohn drag bar and stock springs on my car.
RAGENZ28
04-20-2008, 07:22 PM
I run a 150 pound 10" spring with an adjustable spring perches. If you had it powder coated so what, grind it off then repaint that spot. A car like yours built for drag racing, I would think would use dedicated drag designed parts.
ssfast99
04-20-2008, 11:47 PM
where did you get the springs from ^^^. the whole setup still uses a torque arm but has extensive suspension work done to it. i beleive it is the only S&W race car equipped 9" car running a true 4" exhaust all the way to the back of the car. i have never seen suspension like what my fabricator built for it. the spring is the last of the setup i need because i am going to try the drag bar until the new 6.6 high comp, solid roller, nitrous motor is done and will move to a bar setup from one of the sponsors that connect from the rear to the frame (forgot what they call it).
ragenz28 i have followed your car and love it, 40" is awesome. where in cali is port hueneme, are you going to LA INVASION?
SlickVert
04-21-2008, 08:48 PM
Call Madman!
All the fastest guys have.
Bob
RAGENZ28
04-24-2008, 05:00 PM
Port hueneme is in ventura county off the beach, I am 1 hour north west of los angeles off the coast.
Whats the LA Invasion?????? and when is it I'll go.
ssfast99
04-25-2008, 08:00 PM
look in the western forum for LA Invasion. it should be a sticky, only 150 cars max and we have the whole track to our selves. there should be some fast as hell cars going out. if you can make it i would love to check out your car.
http://ls1tech.com/forums/showthread.php?t=780750
RAGENZ28
05-01-2008, 09:15 PM
My car doesn't drive lol, but I'll look at the link. Might try to make the Saturday event to watch some racing =)
RAGENZ28
05-05-2008, 10:41 PM
I'll be at the monday event to watch the racing if you go.
