drive by wire inop???
ok I got my 5.3 started, but the when i push the gas pedal nothing happends, i have the tac module and the pedal all hooked up, is it true that sometime you have to let the vehicle idle for 8-10 min. for it to learn it self agian after a tune??? any ideas????
You need to run a scan tool on it and see what codes it has. Since it's inoperative it has codes stored. Anything less and you will we wasting your time. It should work immediately provided the tps' are within range, and the tac module has power and communications with the pcm.
Who programmed your computer? When I had my computer flashed the first time the programmer assumed I was going to use a cable throttlebody. It would start but would only idle. I would check this as well as trying to pull codes.
I have my oil pressure sensor pulled out and do not have this issue.
When my TB was a dud, it would re-set the blade, but would not operate. If you can get your hands on another one to test, give it a go.
