Crank Freeze Plug
Crank Freeze Plug
This is the plug that goes in the back of the crank behind the piolet bearing. Does anyone know how to keep this from leaking? I messed mine up during a clutch install and put a new one in from the local auto parts store and now the new one is leaking oil. What can I do to get one in so it wont leak or get this one to stop leaking?
Wow, very helpful I did not get one from the dealer but whats the chances if I do it will also leak? Also what do you use to install it so you know it goes even?
