adj. panhard need with only 9.5/275's in back?
Old 04-17-2008, 11:15 PM
lt1noob's Avatar
Default adj. panhard need with only 9.5/275's in back?
i know an adj. panhard bar is good but is it going to be needed with only 9.5s in back? stock wheels are only 9s so i dont know if itll make enough of a difference that ill need one.
Old 04-17-2008, 11:41 PM
99Bluz28's Avatar
I seriously doubt it, If no rubbing (inner or outer fender)no problem.
Old 04-18-2008, 06:32 AM
koolaid_kid's Avatar
It is used to center your rear, left to right. Check your current alignment to see if they are the same. Mine was shifted to toward the passenger's side by 13/16". It is now perfectly centered.
Old 04-18-2008, 08:07 AM
95GreenZ28's Avatar
If you are lowered I would suggest it
Old 04-18-2008, 09:47 AM
tylerdj's Avatar
Old 04-18-2008, 01:21 PM
lt1noob's Avatar
alright. thanks.
Old 04-19-2008, 08:49 AM
Viper's Avatar
I needed it because of the offset on my Fikse rims (9.5" 275/40/17) puts the rims right out to the edge. I also had to roll the rear fenders as it was eating into my tires.
