non-adjustable torque arm question
If i get a UMI or BMR non adjustable torque arm for my lowered car would it help any? my car is lowred on stranos and i was reading the pinion angle on these TA's are for stock height cars. So what would happen if i put the TA on my lowered car? Will i gain or lose anything? I dont like messing with adjustable stuff so i prefer the non-adjustable TA. bolt on and go!!
any help would be great. Thanks
LS1TECH Sponsor
I don't think there is anything wrong with going non-adjustable...... you are still getting a much stiffer TA, and flex in TA's doesn't plant the axle as well. You'd have no issue with running an non-adjustable on your car with my springs, after all your stock one isn't adjustable and that's not a problem.
Adjusting a TA isn't real difficult, but it's not for everyone, and I can't say you gain tons with the little bit of pinion angle you can run before you can't go further because of binding u-joints. I think the stiffer, stronger part is much more important.
If we can help you out with a UMI TA, (both the adjustables and non-adjust are on my website) just let me know.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
