Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
406 550-600fwhp???/
Old 04-18-2008, 03:30 PM
SlowZ28/SS's Avatar
Default 406 550-600fwhp???/
Hey guys. I'm building a 406 after all the discussion of stroking it out even more. I'm wanting to keep this thing fairly streetable but not to concerned about gas mileage. Looking for 550-600fwhp. The heads flow well over 300 at .600, I dont have the flow sheets in front of me so i cant be exact. i'm looking for a cam that would make this power using a hydraulic roller setup not solid. also the compression will be 10.5 to 1.
Old 04-19-2008, 10:48 AM
In-Zane Moderator
ZONES89RS's Avatar
It is possible but you will have to have a huge bump stick and a huge stall, bump the comression to the 93 octane limit of 11 to 1 if you have aluminum heads, you need good lifters so they dont fade under high RPM, shouldnt be a problem.
Old 04-19-2008, 11:50 AM
moge11's Avatar
Id run at least 11.3:1 or so.
Old 04-19-2008, 06:09 PM
In-Zane Moderator
ZONES89RS's Avatar
On 93 octane?
Old 04-19-2008, 11:39 PM
moge11's Avatar
Yeah, with good quench, Polished chambers, a flattop piston, a good cooling system, and a BIG cam
Old 04-19-2008, 11:50 PM
In-Zane Moderator
ZONES89RS's Avatar
What LSA? I am praying my 112 LSA wont cause detonation in my build, it is aluminum with polished chambers i think ill be ok.
Old 04-20-2008, 01:01 AM
camaro75racer's Avatar
I cant say much about it with the hydraulic roller but my 406 made 514rwhp 564rwtq with the setup in sig. Alot of it has to do with the weight/prep of the internals on my motor but there are other ways to get there without the huge cam. Talk to a engine builder that you can trust they will help you alot. BTW mines right a 10:1 and runs very nicely on 93oct with very good street manners on 3000 stall and 3.42's.
Old 04-20-2008, 12:43 PM
In-Zane Moderator
ZONES89RS's Avatar
So, is there anything done to the pro toplines in your sig? I didnt think they werent that great.
Old 04-20-2008, 01:52 PM
SlowZ28/SS's Avatar
What's the spec's on the cam if you dont mind me asking?
Old 04-20-2008, 02:27 PM
The head were completely worked over by Gene Fultons shop. (Fulton Race Engines) The cam is a Comp part # 12-940-9 its a 290/300 .645/.630 its not really a street cam but the guy that built my motor said it would put me in the power range i wanted so i went with it. Also the carb was really worked over so its nowhere a 670 street avenger it started off as. This motor was a joint build with 2 shops..Fulton Race Engines and Dyer Racing and they really knew what they were doing. The only bad thing i can say about it is that i should have done this setup with a 350 because it really likes higher rpm's.
Old 04-20-2008, 05:04 PM
In-Zane Moderator
ZONES89RS's Avatar
With a 350 it would have liked even more RPM, id be glad you did 400. That is a problem with the 383 kina but they reccomended moving y operating RPM range to 4000-8000, i dont think i want a camthat size on the street at all, much less a solid roller as much as i drive.
Old 04-20-2008, 06:48 PM
350's just seem to hold together a little better at higher rpm's. The 400's are a little more fragile up there. The cam really isnt an issue. I dont drive it that much just because i have a DD and love cruising in the GN but it really does have great street manners. I do now that will probably be my last V8 i build for a toy. Since i recently switched my GN over to E85 i decided next project motor will be a turbo 4.3. Ive actually been considering selling my complete setup to start on this setup.
Old 04-20-2008, 07:02 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, a 350 has allot less rotating mass and a shorter stroke, it will of course respond beter to high revs.
Quick Reply: 406 550-600fwhp???/
