Pinion Angle on a Lowered Car???
Old 04-18-2008, 04:18 PM
DTB_LS1's Avatar
Default Pinion Angle on a Lowered Car???
I will be installing Koni 4/4s and Hotchkis Springs this weekend. My car already has a UMI Adj. Tunel Mount T/A on it and it's set at -2. Will I need to readjust it or will the the pinion angle stay the same?
Old 04-18-2008, 10:01 PM
DTB_LS1's Avatar
Anyone?
Old 04-18-2008, 10:41 PM
CW00BlackTA's Avatar
It will change. Not sure how much but I'd check it to make sure it's where you want it.
Old 04-19-2008, 08:59 AM
Z-RATED94's Avatar
As mentioned, you will have to check. With lowering you will have more positive pinion angle then before. Not much, but enough that you will have to re-adjust.
Quick Reply: Pinion Angle on a Lowered Car???
