i want pistons and rods for heads and cam
Old 04-18-2008, 07:07 PM
PONTIAC SLP's Avatar
Post i want pistons and rods for heads and cam
hi guys good morning
I have a 2001 FIREBIRD Trans Am WS.6 M6 heads and cam and i am planning for nitrous so i want to put pistons and rods, my mods : Patriot LS6 5.7 - STAGE 2 (2.02/1.57/59cc) , G5x3 112LSA Cam , i will put compstar 6.125 rods , so what pistons i put ???? for 100-300 of shot
please give me precise details
thanks, Mohammed.
Old 04-18-2008, 08:56 PM
dudeman's Avatar
i would say Diamond. they seem to be pretty good!!!
Old 04-18-2008, 09:44 PM
408z28's Avatar
diamond has the thinnest deck of all ls1 style pistons. Wiseco has the thickest, plus the ring lands are dropped down for heavy spray.
go with the wiseco.
Old 04-19-2008, 07:23 AM
okay guys you tell me diamond and wiseco what specs flat top or what ? can i shoot 100-300 wet with 59cc ? and how much would me the CR and how about that cam i should change it or it will works good ? if any one has a good good combo with my mods please post it here
Old 04-19-2008, 08:16 AM
408z28's Avatar
You have to decide the cc of the dish, its all about what compression you want to run.
Old 04-19-2008, 10:05 AM
BAD2000TA's Avatar
With the 59cc chambers, you're going to have really high compression with a flat top piston. What you probably will need is a dished piston, probably in the -8cc to -10cc range. Here's calculator to help you choose:
http://www.c5frc.com/calculators/Com...Calculator.htm
Also, since you are planning to use nitrous, look for a piston that can handle the abuse. Mahle are made from 4032 alloy, while Diamond, JE, and Wiseco are made from stronger 2618 alloy. The trade-off is the Mahle doesn't expand as much, therfore, you can run a tighter piston-to-wall clearance. Enjoy!
Old 04-19-2008, 12:45 PM
guys how about this combo ?
Patiriot heads 59cc and G5X3 112LSA , JE LS1 Forged Flat Top Piston -2cc Valve Reliefs 3.905 Bore , compstar 6.125 rods , Gasket thickness 0.058 ,the Compression Ratio would be 10.6:1 , how much can i shoot nitrous ?
Old 04-19-2008, 12:53 PM
thanks , i entered that site , see the combo in my last post and give me your opinion about it
