My blown Z exhaust?
Old 04-18-2008, 10:31 PM
Vortech396's Avatar
Default My blown Z exhaust?
Time to start playing with the supercharged Z again.Thought I would ask all you high horsepower guy's this question.
I have Hooker longtubes into a 4" mufflex with spintech muffler right now.
The mufflex always fit like crap and is heavy. My question is should I bolt a 4" Borla XR1 onto the end of the Y-pipe with a turn down or should I put 2 3" Xr1's on the end of each header with turn downs? Which would make more power? I will not be running pipes over the axle just dumping it underneath before the rear axle.
Thanks
John
Old 04-19-2008, 07:51 AM
Vortech396's Avatar
Any of you supercharged high HP cars ever test a single big muffler vs. 2 smaller ones off the collector?
Thanks again
John
Old 04-19-2008, 08:38 AM
deadmanTA's Avatar
There was a guy that put 2 3" bullets off each collector then into an X-pipe that ended in boom tubes coming out infront of the rear tires. I'm not a SC guy, but I think that 2 3" would flow more than 1 4" because there's more volume going out.
