spring ????
Sportlines are too low as it is. If you insist on using them leave the rear isolator in...you need as much travel as you can get. To answer your question, the hose mod will make the car sit level (no rake). I have sportlines on my car (bought it that way...stranos in june!) and I put the stock rear springs back in with the hose mod to try and help from scraping on everything.
