Anybody seen these? Comp Cams Rockers
Old 08-01-2003, 05:04 PM
WILWAXU's Avatar
Default Anybody seen these? Comp Cams Rockers
I did't realize Comp made rockers for the LS1...
GM LS1 Comp Cams Shaft Mount Rockers
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:LC:MT:1
Old 08-01-2003, 05:06 PM
T/A Medic's Avatar
Default Re: Anybody seen these? Comp Cams Rockers
yeah they just came out in 2003 cataloge with them... same price as T&Ds
Old 08-01-2003, 05:07 PM
T/A Medic's Avatar
unfortunately in the pic i dont see how they would work... because the rockers are offset... ?
Old 08-01-2003, 09:52 PM
WILWAXU's Avatar
More than likely the photo is a standard image.. not the actual product.
Old 08-01-2003, 10:32 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
My installer said he saw them at a show and they are very nice. Suggested, if I wanted a new set of rockers to check these out before deciding to buying a set of Yella Terras.
Old 08-02-2003, 12:24 AM
Larry's Avatar
I have their new catalog and they show 4 kits available for LS1. 1.75 and 1.85 ratio rockers. Both each with either a 5/16" guide plate or 3/8" plate.
They must have two size threads on each end of the studs as they are advertising a 3/8" stud. Our rockers threads are 8mm x 1.25 thread.
They say they are bolt on and fit under factory valve covers.
If anybody want the part numbers email me.
Old 08-02-2003, 03:56 AM
NataSS Inc's Avatar
Thats exactly what I was going to say. I wonder how these would compare to the Jesels?
Old 08-02-2003, 08:07 AM
KRAZY K 2000 TA's Avatar
I love it the new parts just keep rollin in.
Old 08-02-2003, 08:26 PM
eallanboggs's Avatar
Comp also has the Pro Mag pedestal mount type which use guide plates for the pushrods instead of being shaft mounted. They come in either 1.7 or 1.85 ratio for 5/16 or 3/8 pushrods. They cost about $400.00 less. They are high quality are easy to install. I'm sure the shaft mounted type are even easier to install since from the picture it appears that all 8 rockers are mounted on a common shaft meaning you install all 8 of them at a time. What could be easier than that? Just set the preload and your done. Some other shaft mounts are ganged in pairs whereas the Pro Mags must be individually mounted
Old 08-03-2003, 05:19 AM
Flyin'Brian's Avatar
Here are some links I found
http://www.ls1f-body.racenet.net/valvetrain.php
http://www.compcams.com/information/...003/Page-7.pdf
http://www.compcams.com/information/...003/Page-2.pdf
Old 08-04-2003, 06:15 PM
WILWAXU's Avatar
Anyone used ethier setup yet?
