Trickflow Heads w/Scorpion Rockers
Heads are on the bench. I removed 2 valve springs to install checker springs so I can set the proper swipe pattern. Bolted up the Scorpion Rockers with no shims. Rigged up the dial indicator. I used the Sharpe method and colored the top of the valve stem. Simulating the lift of the cam at .631 on the intake, I checked the pattern. The pattern was on the intake side of the stem. I then removed the rockers and added a .047 shim. Checked again and noticed I could only get .620 of range on the rocker before it would bind on the bolt. The pattern was closer to the center but not quite. I added another .047 shim and that limited the range to .427.
So, I assume the rockers will not work with the Trickflows f'ed up geometry. I cannot achieve the propper pattern without shims. With shims I cannot get the necessary lift before the rocker binds on the bolt.
Thoughts???
Thoughts???
I bought ARP bolts to go with the Scorpions. I didn't keep the stock bolts when I got the HS. The ARP's are shorter than stock. I hope I don't have another issue to deal with. I ordered YT's today, fingers crossed.
