Main Reason For Boost Controller
I know what its for but what I mean is if your car is just a street car do you really need one.I plan on 15lbs of boost all the time tuned sd,so do I need to run a bc or not.What would you guys do and what controller are you guys running.
Thanks
Brad
Thanks
Brad
You need a boost controller if you wish to ever change the boost higher then the wastegate spring. I would go with a manual boost controller to save on cost if you don't mind having to turn the **** when you want it higher.
You can always add the boost controller at a later time.
Exactly what he said, I have a 9psi spring and plan on running that to start but also have a manual b/c that I'll hook up for now. In the future I plan on buying the Hallman pro mbc that has the in cab kit to change it on the fly inside the vehicle. I think it go's for about 150 on ebay and is one of the best you can get for a manual.
Thanks
Brad
I have a 15lb spring in my wastegate,do you think I should go with a smaller spring and run a boost controller to turn the boost up when I need to.I seen that Hallman Pro on the internet for like $100 when I did a search for boost controllers.I just wasn't sure how good a manual controller would be.
Thanks
Brad
Thanks
Brad
Being that you have a 15psi spring you could jsut run off of the wastegate spring and have 15 psi all the time not needing a controller. If you want to set it lower, yes you'd need a lower spring and a controller. This is what I'll be doing with my 9psi spring which will be the low setting and 15 my high or anywhere in b/w with the manual.
edit - jsut looked its called the Hallman Evolution RX Kit manual boost controller. Not sure if they offer the normal ball or jsut the ceramic one but if you get it get the one with the ceramic, which is thus the Pro. This one is for 146 bucks which I'll get down the road. Spending enough money on everything else right now!
