car sits uneven
car sits uneven
didnt know if i should put this in here or in suspension
ive got afcos up front both of them are set ecactly the same...brand new...both are compressed 6 turns from the bottom
rear springs are stock without isolaters...i have lowering springs with the same problems back end sits about an inch differant....whats causing this
this is my car fender height at each corner in order
LF 25.75 RF 26.75
LR 27.25 RR 29
car has no bumper supports
no front swaybar
rear wolfe bar set loose
comp drag shocks out back
afco coil overs out front
is it ok to adjust the afcos enequally? and the rear springs cut them to make them sit evenly? or is ther something im missing about this?
LF 25.75 RF 26.75
LR 27.25 RR 29
no front swaybar
might have a sagging lr spring. when you sit in your car (depending on weight) drivers side will sit 1/2" lower (again, based on weight) so you're looking at(based on original 25.75") 25.25" on LF and still 26.75 RF so i'd say lower RF 1.25" and swap springs in rear around and see if that will solve your prob.
