Dark clutch fluid...
Old 04-19-2008, 10:37 PM
Green3spd's Avatar
Default Dark clutch fluid...
I checked my clutch fluid last night and the reservoir was low and the fluid was VERY DARK... how do I change this, is there a bleeding system...? This cant be good for it? Right?
(my first 6spd)
Old 04-19-2008, 11:15 PM
wrencher
wrencher's Avatar
You have a leak somewhere if it is low.
Look at the master inside at the firewall where the rod goes into it from the pedal for seapage. You might need a master.
But bleeding is good for it, fresh fluid will improve the pedal feel every time.
It is an LT1 though right? If so there might be a allen on the external slave you can bleed it with. Otherwise you have to bleed it with the factory meatod like a mity-vac.
Old 04-20-2008, 03:30 AM
The_Wretched's Avatar
that happened to me as well... my fix was a new master and slave.
sucks... it can get pricey to fix.
is your pedal sticking??
Old 04-21-2008, 08:34 PM
Green3spd's Avatar
not sticking... driving fine... just looked low and dark.
Old 04-21-2008, 08:54 PM
CTSmechanic's Avatar
DARK not black is normal if its a little low it can be diplacement from wearing clutch material or.. a leak
Old 04-22-2008, 10:50 AM
SPEC-01's Avatar
The easiest thing to do is to flush and refill the hydraulics using a fluid with a higher boiling point. You may also want to check your hydraulic lines and insure that they are routed behind the heat-sheild near the header. You can also wrap the lines with a heat-resistent wrap. Please let me know if you have any further questions. Thanks!!
Old 04-23-2008, 09:49 AM
Green3spd's Avatar
I DO!... I have many more questions... Ive only owned auto fbodys so this is my first 6spd... Ive never changed a clutch or the fluid....
How do I change the fluid?
