View Poll Results: Better street heads for 224 cam
5.3 heads
51
60.00%
5.7 ls6 heads
34
40.00%
Voters: 85. You may not vote on this poll
224 cam...5.3 or 5.7 heads?
Old 04-20-2008, 12:51 AM
kingsey's Avatar
Default 224 cam...5.3 or 5.7 heads?
Street car...people are split between them 50/50
224R on a 112 lsa
Looking for best power for the street
Old 04-20-2008, 03:58 AM
mchdg86's Avatar
I like my 5.3 heads. Put me at 400 rwhp with a locked stalled auto.
Old 04-20-2008, 07:48 PM
kingsey's Avatar
Lots of views. Any more people care to share?
Old 04-20-2008, 10:54 PM
TransAmcoupe98's Avatar
5.3 heads dumdumdum
Old 04-20-2008, 11:30 PM
Midnight02's Avatar
Just had to make this decision myself....I went with the 5.3 heads because I'm building a street car and wanted to keep the head swap on a bit of a budget. If my car was a track car and I was looking for the ABSOLUTE best performance out of the stock cubed LS1, I would've went with the AFR 205's or the TFS 215's (5.7 castings).
Old 04-21-2008, 01:14 AM
99blancoSS's Avatar
I had the 5.3's and always saw more power being out down with ls6's. I'd opt for the MTI's on sale right now.
Old 04-21-2008, 02:32 AM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I recently installed a set of PRC CNC 5.3L 2.5 heads and a 228R|114lsa on a 98 Camaro with a LS6 Intake, TCI 3500 converter and Pacesetters. This was for one of my brothers coworkers at his workplace. It picked up approximately 90rwhp through a stalled automatic.
Before the heads and cam the car was running consistent 12.7-12.8's in 4500-5000DA of air. After the H/C install and tuning the car immediately went to running 11.7 @ 116mph with the same air. I drove this car around for a week before I delivered it and it was one of the nicest driving F-body setups I've ever driven. You could barely tell it was modded during regular commute type driving.
Old 04-21-2008, 07:45 AM
BIG_MIKE2005's Avatar
I absolutely love my 5.3 & 224 combo. And like stated above for a street machine this is your combo. It will make more torque down low which is what you want on the street. And it'll bump up your compression a little too, which helps out.
Old 04-21-2008, 09:09 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Also remember, our heads are on special as well I agree that the 5.3L heads would be a great addition to your vehicle currently. The slight boost in compression along with THE shortest CNC'd 5.3L intake runner available today make for a fun street/strip cruiser!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-24-2008, 03:39 PM
danf1000's Avatar
5.3 for torque street fighter combination.
Old 04-24-2008, 06:02 PM
VIPERBLUELX's Avatar
why the small cam?
Old 04-24-2008, 07:58 PM
camaroIroc's Avatar
I got a question, Im new to this site and I am hoping someone can help me.
I have a 5.3 LM7 (1999), and I want to run this stock LS2 cam (.500in, .500exh, @.050 dur)..does anyone know what type of valve springs I may need, or if anyone has ran this application? Im also runnin an LS2 intake.
thanks in advance.
Old 04-25-2008, 06:21 AM
Originally Posted by VIPERBLUELX
why the small cam?
Why not?? These 224 cams have carried many full weight street cars into the 11's just fine. You don't need a big cam to turn a good ET. Peak power doesn't mean anything to me. I'd much rather see a smooth power/torque curve climbing all the way to my shift point. These cams do exactly that.
Old 04-30-2008, 11:14 PM
eamador11's Avatar
thanks in advance.
Old 05-01-2008, 10:22 AM
zman1969's Avatar
Default ?
why would you recomend them? they are double what Tx Speed gets for their awsome looking 5.3's ? I really dont see the value in that. seems like the question posed was budget minded - bang for the buck
Old 05-01-2008, 10:47 AM
It's also about you goals. The LS6 casting will flow higher at higher RPM's, but the 5.3 will bump your compression & make more torque.
If you like dyno numbers & spend most your cars life on the track, then the 243 cast heads are the route to go. But if your a every now & again track car while the rest of the time it's street driven then 5.3's are the better route.
Old 05-01-2008, 01:48 PM
jmmullin's Avatar
I'd say 5.3's; its what I have and my cam is 232/234...
That cam, being a pretty mild one, has some smaller lift #s...Probably wouldn't be very beneficial to go with the better-flowing ls6 castings...the bigger compression from the 5.3's would outweigh the better flow from the LS6 heads in my opinion, though I would think the difference would only be about 10 rwhp... LS6 heads are slightly more expensive I believe.
Old 05-02-2008, 01:56 PM
radkon's Avatar
The real question is if you were to mill the LS6 heads for the same compression ratio which heads would you choose?
Old 05-02-2008, 02:31 PM
JZ28's Avatar
I can tell you exactly how that combo works. I have the 224 112LSA cam with TSP 5.3 heads. I had the heads milled a little extra for ~11.25 compression. On the dyno it put down 415rwhp/402rwt, those are SAE corrected #'s. Torque is the best part. Makes over 300 lb/ft at the wheels from 2k all the way through redline. Makes over 350 from 3k-6k. GREAT street setup. My car is a 6-speed by the way.
Old 05-03-2008, 11:43 PM
kingsey's Avatar
So if i go to the 5.3's i have to replace my brand new pushrods?
I was tossing around the idea of just going with stock ls6 zo6 heads if they would get me auther 20rwhp compaired to 35 for anuther 700 bucks
Or am i thinking like a moron about the stock ls6 heads?
