My new bonestock LS1 is here...now what...
Old 04-20-2008, 01:13 PM
brianatfum's Avatar
Default My new bonestock LS1 is here...now what...
Hi there,
It's a 2002 A4 Z-28 Camaro...
I am debating on my first mods...
Should I first go....
LT's,TSP TD and Lid
OR
Yank T/C and 3:73 gears
It seems so easy for me to give other guys advice about their car but when it comes to mine... my mind goes
Old 04-20-2008, 01:46 PM
jsteele90's Avatar
think youre in the wrong forum for this but. i would recommend lid,cutout,gears, and some sticky tires. then maybe some lts,catback and definately a stall.
Old 04-20-2008, 02:01 PM
TXZ28LS1's Avatar
yeah wrong section.. but i would do lid, yank, and longtubes for first round of mods.
Old 04-20-2008, 02:17 PM
Machinist's Avatar
Definetaly stall first.
Old 04-20-2008, 02:22 PM
turbo_passat's Avatar
Since your auto, instead of performance mods, Id go ahead and get the rear end out of the way. Just so you wont have to worry in the future. My .02
Old 04-20-2008, 02:41 PM
Pontiacerator
RevGTO's Avatar
Get a lid. If you have 2.73's, get gears. If you have 3.23's keep 'em.
Then, if you want bang for the buck, get the Yank, and put a Hooker muffler in your stock system. You can sell it when you've saved up enough for your LT/TD set-up.
Old 04-20-2008, 03:31 PM
b00sted's Avatar
th400...
Old 04-20-2008, 11:14 PM
brianatfum's Avatar
Why rear first? It's not a M6 and will probably see the track maybe 4-5 times a year.
Old 04-20-2008, 11:15 PM
brianatfum's Avatar
Originally Posted by b00sted
th400...
Seriously?
Old 04-20-2008, 11:40 PM
Ryan33187's Avatar
Agreed on the rear-end convo hes not a m6 he will be fine with that a4 preloading the rear-end. As for the th400 do you wanna lose overdrive or not? You say 4-5 times a year for the track so I'm guessing its a daily driver I would just get a built 4l60e or swap to a 4l80e. All in all I would go LTS,TDS, and lid first. Then put stall in after you get or while you get your cam, injectors, oil pump, springs, timing chain and pushrods in and the dyno tune.
Or go the other way and build a nice suspension then work on your performance mods so you can really plant all your power to the ground...
Old 04-20-2008, 11:57 PM
brianatfum's Avatar
I do not do a lot of highway driving. However, I will be putting down 5xx-7xx hp. So, maybe a TH400.
