pvc question
pvc question
i have a torque v3 cam from tsp (231/234 .643"/.598" 111 LSA)
im going to be running some ls6 heads that have been milled .020-.030 think there will be any need to flycutt? ill be checking it anyways while i have everything apart.
what do you think?
what do you think?
Well I would be making arrangements to flycut with that cam anyway, let alone the milled heads. Better to do it now than breaking stuff and then doing it later.
LS1Tech Premium Sponsor
It will be really pretty tight. We build our heads with custom valve heights to give extra clearance for additional decking. Im just not sure if a standard ls6 can work with that much decking.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
