ABS issue
ABS issue
My '99 Z28 has developed a weird problem. The ABS inop light and the ASR off light will come on at 60 mph or greater. Doesnt do it until that speed. What can I do? Is there a fuse I can pull as a temporary dummy fix that will keep the lights from coming on? What could be my problem? Any help would be great.
I'd start with the connectors too the ABS unit,also on the wheels. They might be loose.
Someone with a HP Tuner might get a better reading and point you in the right direction.
Sorry I couldn't be anymore help.
It seems to have started after I remounted the wheels when I got new tires for it 3 weeks ago. When I get time this week I will check the ABS sensor connections. Keep the help coming.
