Best cam to make peak power ~ 5800-6000, shift points 6200-6300 for A4??
Old 04-21-2008, 09:18 AM
Kenny H's Avatar
Default Best cam to make peak power ~ 5800-6000, shift points 6200-6300 for A4??
I want to keep the power band LOW in an effort to not destroy my A4. The car will have full bolt-ons and a Vig 3200. What sort of grinds should I be looking at to keep that powerband very low? I will stay with stock heads and I want a decent idle. Ideally I'm thinking something that peaks shy of 6k and I can shift at 6200 or so. Any ideas??
Old 04-21-2008, 09:24 AM
s346k's Avatar
you're already running the best cam for your goals.
Old 04-21-2008, 09:32 AM
Hell'sChariot's Avatar
Im shifting at 6100rpm with my tr224 112, stalled a4. I moving up to the tr230 now, and will probably move shift points to 6300rpm tops.
Old 04-21-2008, 09:49 AM
hammertime's Avatar
I disagree, I think you could make a pretty significant improvement by going with a small cam. A 218/220 110+1 cam cut on XFI intake and XE-R lobes would make for a great cam with headers. If the OP plans to keep the stock exhaust manifolds, the next smaller 214 XFI lobe combined with the XE-R 220 lobe on a 112+0 grind is a good compromise.
Old 04-21-2008, 09:51 AM
Dragkid1917's Avatar
you could always just advance the cam on install to shift peak power.
Old 04-21-2008, 10:16 AM
MJD
MJD's Avatar
I run a vinci grind, 222/228 duration. Check my sig for dyno. I shift at about 6200. I will say it will make a difference on who tunes the car as well. Before my second tune I didn't peak until 6400. After a better tune my powerband shifted down in the rpm range.
Old 04-21-2008, 10:34 AM
TXZ28LS1's Avatar
your safest best is the tried and true 224/224 cams!! one of the best proven cams around for daily drivers.
Old 04-21-2008, 11:25 AM
JS
JS's Avatar
Kenny the TR224 is the cam to run
6200 shift point w/stock heads in my old WS6..
Idled great (112LSA) and made killer tq and ran 11.60's@3500lbs
IMO the TR224 is the best cam only Street/Strip DD cam u can run
Old 04-21-2008, 12:04 PM
5_02ls1's Avatar
224/224 on a 112 my buddies car has this cam and hhe shifts around 61ish....made 378 on a stalled a4
Old 04-21-2008, 01:35 PM
99blancoSS's Avatar
If you call Thunder they can tell you the ideal shift point. I ran the TR224 112 lsa with an M6 and was told to shift at 64-6500. We have a guy in our section who ran 12.1 all day long with it and a stall and some bolt ons.
Old 04-21-2008, 02:46 PM
PREDATOR-Z's Avatar
224/224 .609/.581 111+4 LSA
This will be a very, very torquey cam with the shifts you are asking for.
Old 04-21-2008, 06:22 PM
Alex99's Avatar
I would second hammertime's suggestion for a setup (although with a stock converter).
I ordered the XFI 214 intake and a LSL 218 exhaust lobe and 111 LSA +0.
The grind came out at 216/.600 and 219/.609 @ 113 LSA +0
The car runs and idles like stock with massive torque in the midrange. I shift at 6100 with my A4.
The mileage went up also.
I would take the same cam again but maybe with less LSA for even more DCR. I daily drive my vette so I need something that has a close-to-stock behaviour.
Old 04-21-2008, 08:14 PM
Kenny H's Avatar
Thats what I'm leaning towards JS. You told me a few months back to get a Vig 3200 and I'll be going that route as well. Any other suggestions?
Thanks for your help!!
Old 04-21-2008, 08:16 PM
Kenny H's Avatar
This is a touch more lift than the Thunder 224. Will it make a tad more power? Sorry to the dumb question, but the +4 will just mean the power will come in sooner, correct?
Old 04-21-2008, 08:57 PM
christian miller's Avatar
What about the Vengeance Racing VRX4 cam, 228/230/588/592? that might be a good one.
Old 04-21-2008, 10:01 PM
PREDATOR-Z's Avatar
yes more power,more trq, in the shift band you desire. properly degreed and tuned, I wouldn't be surprised by 400rwhp/400rwtq results
Old 04-21-2008, 11:33 PM
405HP_Z06's Avatar
^^^^^Agree Vinci XXX, this is a nice cam. Easy to tune, drives nice, and makes great power. I have the same cam.
Old 04-21-2008, 11:35 PM
mchdg86's Avatar
another vote for a 224 on a 112.
Old 04-30-2008, 03:37 PM
JunkyardZ's Avatar
Would you guys recommend the XFI lobes for this cam size?
Old 04-30-2008, 11:25 PM
eamador11's Avatar
I agree,at a 114 LSA nice and smooth idle
TR224@114 from thunder racing
Quick Reply: Best cam to make peak power ~ 5800-6000, shift points 6200-6300 for A4??
