TR-7 a colder plug than a TR-8????
Old 04-21-2008, 02:38 PM
koolrayz's Avatar
Default TR-7 a colder plug than a TR-8????
I was looking at the TR7 & TR8 plugs I have at home. The TR8 are boxed as #7317 R5724-8 The TR7 are marked #3346 BR7EF.
The TR7 electrode barely extends past the base of the threads, no porcelane extends past it. On the TR-8's the tip protrudes much further out than the TR-7's?? When I hold the TR6, 7, 8 all together the 7's look to be by far the coldest plug. I thought the colder the plug the less protrusion????
Old 04-21-2008, 04:12 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'm no expert on plugs, but a TR8 is a colder plug than the TR7. There's been talk in the nitrous section a lot about plugs. You might want to look around in there.
Old 04-21-2008, 04:34 PM
XtraCajunSS's Avatar
TR8 is colder than TR7.
Shane
Old 04-21-2008, 05:30 PM
koolrayz's Avatar
That doesnt answer the question of why a plug with a colder number (TR8's) protrude further into the combustion chamber than the TR-7
Old 04-21-2008, 05:39 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The longer reach into the chamber does not make it a colder/warmer plug. The reason one is longer than the other here is that they are different series (the numbers before and after the heat range dictate reach and such of the plug). The heat range is dictated by the length of the insulated nose, which you can only see very little of without cutting the plug open (see page 2 of link below)
http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
There a little info from NGK on the subject.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-21-2008, 05:48 PM
koolrayz's Avatar
Now I got it thanks thats a great link
Old 04-21-2008, 05:55 PM
Glad to help!
__________________
