Knocking noise after knock sensor replacement!
Old 04-21-2008, 08:39 PM
98whiteFormula's Avatar
Default Knocking noise after knock sensor replacement!
working on my brother's '01 WS6,replace both knock sensors.put everything back together.car makes knocking noise.No codes,engine oil pressure good.turn motor by hand thru crank,motor turns good.any ideas or those had same problem when replacing knock sensor.any inputs from you guys will really help.
Old 08-29-2008, 05:03 PM
SSmafia's Avatar
Wierd because this happened to me too. I replaced the rear ks. But I thought for some reason that it had always knocked and I just now noticed.
Old 08-29-2008, 05:15 PM
Engine_HP's Avatar
im about to change mine and u guys are scaring me
Quick Reply: Knocking noise after knock sensor replacement!
