Ported afr225's.. too big for 346 cubes?
Old 04-21-2008, 08:51 PM
Dragkid1917's Avatar
Default Ported afr225's.. too big for 346 cubes?
I shouldnt even tempt myself with this question and talk of buying heads, bbbbuuuutttttt.... Are ported afr 225's too much for a 346 cubic inch motor, maybe with 62 cc chambers to keep the compression up?. I Plan on having the mods in my sig, plus ported fast 92/ 92 mm tb combo, a UD pulley and possibly a water pump. Any thoughts on this? If im going to do heads i want to make around 475 or a bit more to the wheels....
Old 04-21-2008, 09:01 PM
JonCR96Z's Avatar
You've got to think about all the people who put Patriots and other ported stock castings on their cars. They are usually 220+ cc. So you really wouldn't be no different from those cars with the exception of more flow across the board, thicker deck, double quench pad, and whatever else.
Old 04-21-2008, 09:11 PM
405HP_Z06's Avatar
AFR 225's out of the box are closer to 229cc's, and porting them will probably put them in the 235 - 237cc range if Tony ports them. They would be an excellent choice for a 346.
Old 04-22-2008, 03:18 AM
pdd
pdd's Avatar
I dont think they'd be an excellent choice for a 346 at 235cc. I think u'd lose a lot of low end
Old 04-22-2008, 07:36 AM
redtail2426's Avatar
at 235 cc i think you would be alright.Just keep your quench tight and both your static and dynamic compression high.
Old 04-22-2008, 09:45 AM
how high is high.... like... 11.2:1 / 8.4:1....?
Old 04-22-2008, 09:59 AM
DannoWS6's Avatar
I wouldn't recommend it on a stock cube N/A motor with that cam. Sure it will work, but the curve is really gonna hurt. More cubes/bigger cam/FI then yes, especially if you wanna street drive the car I think you would be happier with a stock casting from Trickflow or ETP in the 215 range.
You do know a 205 head will support over 800hp on these motors, so the runner size is not the limiting factor.
AFR makes the 225 in a small bore version, if these are the small bore than it might not be as bad of an option. But, I bet if you talked to most who build street cars and keep the rpms under 7k they would talk you out of that head for your setup.
Regardless of the heads you get if you stick to N/A I would bump the CR up to about 11:1.
Old 04-22-2008, 12:09 PM
so would you say that the ported 205's are better than a small bore ported 225? lets say with a 62 cc chamber?... idk about that...
Old 04-22-2008, 12:29 PM
SOMbitch's Avatar
Go read Pat G's "how to make 500 HP thread. He picked up gas mileage and throttle response when he went to the AFR 205's over the 225's.
DannoWS6's Avatar
Depends on your ultimate goal. If you are going to keep that cam and stay N/A with that converter then I think 205's are your better option. If you like to street drive your car and mid lifts and throttle response is desired than 205's are better.
If you are looking for every once of peak power and you are willing to get a bigger stall and spin the motor high than 225's might do you better. Or if you have future plans for more cubes or FI it might be a decent option to keep em.
I am pretty happy w/ my 205's and will probably reuse them on a 402 build later. If your in the market to buy any head I would probably consider the ETP or trickflow heads. Those heads have the bigger runner's but it's the lower degree design (think Trickflows are 11*) that help make some nice mid and high lift number's. AFR's are carbed stamped and have a nice deck and rocker studs and in the hands of a good porter can make sick power.
With that said if I was you I would guy w/ 205's over the 225's. w/ 62cc chamber's you will probably have to flycut as well, but that's no big deal. 62cc will probably get you a high 10:1 using the stock gasket.
Old 04-22-2008, 12:39 PM
humm... ill have to ponder this for a while.... i wish i there were flow charts of fully ported peices by all 3 of those brands...
Old 04-22-2008, 12:57 PM
DannoWS6's Avatar
Picking a head is more than just flow number's, don't get caught up in the number's game.
Guys post dyno and track results all the time here, read up on posts from Vengeance racing, Tony Mamo from AFR, and Cartek. Those guys not only make fast track car's but car's that you can pretty much D/D.
Old 04-22-2008, 02:01 PM
yhea its a long way off anyway I was just tryin to get an insight into what i might wanto do down the road... Heads are just way too expensive to mess around with, and if im gunna do them i want to see some serious power gains....
Old 04-22-2008, 03:17 PM
RAGENZ28's Avatar
Don't know where this info comes from but no one has ever made 800 hp with a 205cc head N/A. Just run enough compression and a good size cam, at least 230@.050+ duration and it'll be great.
225 cc isn't huge, people run way bigger than that on race motors even with small cubic inch motors. Just keep in mind the more power you want N/A the higher you'll have to spin the motor, so if you're looking to make max power with a 346 the 225 is the way to go vs the 205cc.
I've seen 350-373's make 800+ hp N/A but trust me they didn't use a 205cc head.
Old 04-22-2008, 07:00 PM
eamador11's Avatar
wow, just wow! 225s are for a 4.0 bore and higher.
Old 04-22-2008, 07:01 PM
eamador11's Avatar
please put the crack pipe down...holy crap!!! stock castings are 205cc.....
Old 04-22-2008, 07:46 PM
venom ws7's Avatar
If this is a N/A setup 346ci H/C/I I would go with 205 AFR And port them
they will work awesome with right csm 470rwhp is not a problem
Let Tony port the heads and the intake his work is great.
Old 04-22-2008, 07:53 PM
allngn_c5's Avatar
I would also suggest getting a set of AFR 205's and have Tony Mamo lay his hands on them and work some magic before you get them. Option 2 would be to get some out of the box TFS 215's. Either way you will be happy. My m6 346 made 490 rwhp 445 rwtq. Not too shabby.
Old 04-22-2008, 08:02 PM
trick flow 215's?... i head something about needing new rockers and pushrods.... what was your experience with that?...
Old 04-22-2008, 08:08 PM
allngn_c5's Avatar
Not sure bro. Maybe someone else can fill in that one.
Quick Reply: Ported afr225's.. too big for 346 cubes?
