new set up, what gap to go with?
what should i gap my spark plugs to? NGK TR6's
new setup (not yet installed, lol):
Ported lq9 heads
ls6 cam
custom 76mm turbo kit
stock bottom end
9 lbs boost...
what gap?
any hp estimate? im hoping about 550 rwhp, since my car runs like a freak anyways...
Ported lq9 heads
ls6 cam
stock bottom end
9 lbs boost...
what gap?
No kidding, M6 I'm guessing? I'd be real pissed if you don't hit 600 honestly on 9 psi. Make sure your tune is dead-on, 9 lbs on a stock bottom is pushing it. You're creating alot of cylinder pressure for stock pistons/rings with that much boost. I think you'll hit your 550 goal with 5-7 lbs (depending on how efficient the kit is) and be easier on the motor.
