Timing chain play
Old 04-22-2008, 03:46 PM
ls1slow's Avatar
Default Timing chain play
I just changed my cam and when i opened it up it was kinda loose on the side in between the gears. When i put it back on it was it was super tight but the sides still had the play in them is this ok is it suppose to be like this.
Old 04-22-2008, 04:21 PM
vettenuts's Avatar
Did you install a new chain? In a nutshell, yes there is some slack.
Old 04-22-2008, 05:56 PM
ls1slow's Avatar
No i didnt but if there smoe slack i think im good
Old 04-22-2008, 08:10 PM
tylerdj's Avatar
I had a small amount of slack when I did my cam swap.
Old 04-23-2008, 08:45 AM
robertbartsch's Avatar
Next time swap the timing set and chain since it is not that much dough. Double chain sets stretch less.
Old 04-23-2008, 09:05 AM
DONAIMIAN's Avatar
The factory chain is designed to be loose.
