3.73 shift points
3.73 shift points
hey guys im gettin a predator to fix my shiftin with my a4(i just got 373s) and i was wonderin what yall set them at thanks
Wes
Wes
Moderator
Re: 3.73 shift points
You set the rear end info up (tire size & gears) first.
Seem to recall you had to "fake it" for 3.73s like use
a different tire size or something.
Then you should change the MPH shiftpoints downward to
(original MPH point)*(original gear)/3.73 - maybe have
to alter it a MPH or two from there, to keep off the
rev limiter. But this should get you to as-it-was shifting.
You can mess it around from there for perfromance tweaking.
