Introducing The All New 1 7/8" TSP Long Tubes!!
Guys we're proud to announce the first batch of Texas Speed 1 7/8" long tube headers for the 4th Gen F-bodies are finally ready! After about 3 months of testing & tweaking we're finally ready to start shipping the first batch of headers! All TSP 1 7/8" long tubes will feature the same quality you've come to expect from Texas Speed!
The headers will feature:
Manufactured using flash-controlled 16-gauge tubing.
Mandrel bent 1 7/8" primaries insure high exhaust flow rates.
Steel head flanges are quality-manufactured to insure a precise fit.
Collector design provides a smooth transition to your exhaust system.
Ceramic coating provides years of trouble free performance with improved heat dissipation
This header setup is designed to fit with the TSP y pipe! This all new header is a great setup for anyone wanting a header that works great on stock cube heads cam cars all the way up to LS7 big cube strokers!
The best part is the TSP headers will give our customers the ability to install 6.2L heads & LS7 style heads without worrying about killing exhaust flow with a small 1 3/4" primary header!
The days of having to spend $800 for a quality 1 7/8" header is finally over!
Here's a few pics of a set before it goes off for ceramic coating.
We will only be offering these heads without AIR or EGR. They will however include all front o2 sensor holes!!
Intro pricing will be $479.99!!!
Enjoy
Enjoy
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Pictures should work now!
__________________
[QUOTE=Matt@Texas-Speed;9219853]Guys we're proud to announce the first batch of Texas Speed 1 7/8" long tube headers for the 3rd Gen F-bodies are finally ready! After about 3 months of testing
DOH! Fixed.
We've got these in stock and ready to roll! No back-orders!
__________________
__________________
All of the Y-pipes that fit the Pacesetter, Hooker, and Jethot headers will fit with these (likely others too).
They have a 3" collector.
__________________
