clutch line and DRiveshaft?
i need a new line from the trans to the cultch master cyclinder anyone know where i can get one? also does anyone have a 1le aluminum drive shaft for an m6 car as i need that to ?
The factory braided line is not available by itself, it's part of the master cylinder "assembly" from GM. Only way to get one new is to buy a new master from GM. There's a thread in this section (a quick search would find it) about getting some aftermarket AN fitting adapters that allow you to use aftermarket AN line with the stock master/slave.......
