Dart Pro1 Spark Plugs
For those of you running Dart Pro1 heads what spark plugs are you using. Dart recommends the following:
1)Autolite 3934
2)NGK FR5
3)NGK BKR6E
The NGK FR5 appears to be an c4 ZR1 spark plug and the autolite 3934 just appears to be a class of spark plug.
So to make sure that I order something that will fit, what spark plug/part number are you using?
1)Autolite 3934
2)NGK FR5
3)NGK BKR6E
I went with the NGK BKR6E. even though its only a slight bump in compression i just wanted a colder plug. The FR5 wouldnt be a bad choice either their just a gasketed TR55.
Personally i wouldnt use an autolite in a GM but im shure its a good plug. Dart just gives you a couple of choices because they require a gasketed plug as apposed to the conical sealed plug that the stock head uses.
I used an NGK BKR6EIX-11, which is one heat range colder than stock. If you use Autolite, here's the numbers/heat ranges:
3924 - Stock heat range
3923 - One heat range colder
For Denso:
IK16 - Stock heat range
IK20 - One heat range colder
All the above part numbers meet the following specs:
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Gap - .059
Installation: 21 lb/ft or 2/3 Turn
For Denso:
Thread – 14mm
Reach – 3/4”
Socket – 5/8 hex
Seat – Gasket
Gap - .059
Will the taper seat work, yes. Is it optimum, no. It's amazing that one would recommend the incorrect part. Why not use what the manufacturer designed the head for?
These heads were designed for a gasket seat spark plug, not a taper seat. The head has a taper machined that happens to work with taper seat plugs, but it's not recommended. A taper seat plug is too short, shrouding the spark from the combustion chamber.
