I Cant Get My Car Tuned!!!!
Old 04-23-2008, 09:40 PM
LS1PHNX's Avatar
Default I Cant Get My Car Tuned!!!!
My car has a basic tune from a local tuner here...i went back to get my car fully tuned because i changed my cam and added some bolt ons...however, he cant tune it because he doesnt receive a signal from my computer. He isnt able to edit anything! he cant even scan my car! so later today, i rented a scanner from autozone, and i was able to scan and read codes that my car was throwing!!!??? what could the problem be???
Old 04-23-2008, 11:12 PM
LS1TECH Sponsor
foff667's Avatar
Possible blown cig lighter fuse would be the first thing I'd check.
Old 04-24-2008, 07:49 AM
YellowToy/A's Avatar
Do you have some kind od scan gage?
Old 04-24-2008, 09:57 AM
Eurospec2's Avatar
If you can read the codes with the autozone scan tool, then its not the cigarette lighter fuse.
What year car/pcm are we talking about here, and what software is your tuner using?
Old 04-24-2008, 12:04 PM
edcmat-l1's Avatar
It can be that if the scanner has a battery pack. My Vetronix will connect to a car if the fuse is blown. Thats just there to power up the scanner.
That being said, I too would like to know the particulars. Like what does the scan tool say when it wont connect?
Old 04-24-2008, 08:47 PM
LS1PHNX's Avatar
my car is a 1998 pontiac trans am...the software that he is using HP tuners....when i put the autozone rental scanner it reads code P0405-egr flow sensor (because i swapped to an LS6 Intake)....and it also reads random misfire due to the bigger cam....the scanner has its own battery pack
Old 04-24-2008, 09:01 PM
LS1PHNX's Avatar
also my tuner was able to get into the computer when it was OFF the car...however he was able to when it was ON the car
Old 04-25-2008, 06:34 AM
Eurospec2's Avatar
Well, most likely then as Ed and Foff pointed out originally if the scanner does have a battery pack, and your tuner can read the PCM outside of the car, then i was probably incorrect and it very may well be your cigarette lighter fuse blown
Old 04-25-2008, 04:49 PM
1SIC_GM's Avatar
It also could be if you have a system on your car...because it could have a loose ground some where in your wiring.All of that is going to your computer.
Old 04-25-2008, 08:34 PM
LS1PHNX's Avatar
i checked all of my fuses and theyre ok....i do have a system in my car and im using my stock deck...
Old 04-25-2008, 09:47 PM
wrencher
wrencher's Avatar
Check for power & ground at the 16 pin DLC.
That car should be J1850 VPW interface protocol
Look at these;
http://www.obd2.com/obdii_dlc_interfaces.htm
http://www.chevymania.com/tech/obdii.htm
serial data info class 2 would be relvant to you
http://www.gmtcny.com/serial%20data.html
Check that there is csome voltage there vararing on the communication line. But only do so with a 10 mega ohm impedance digital volt meter.
Old 04-26-2008, 08:13 AM
Bill Bowling's Avatar
Does your cig lighter work?
Bill
Old 04-27-2008, 11:41 AM
LS1PHNX's Avatar
yeah i checked my cigarette lighter and it works....im still a little confused on why the autozone scanner can scan my car but my tuner isnt able to
