You guys with a VAC/BOOST gauge... what vac are you seeing at idle?
Just curious... I dont think my boost gauge is working correctly and would like to know what is "normal"? I know all cars will be different.. but what is yours showing for VAC at idle?
Thanks.
Thanks.
Right now Im seeing 11-12 in/hg at idle.
Stock LS1, 6.0L heads, blower cam 221/227 580s 114... D1SC.
Well.. while Im here I might as well ask....
Setting my AFPR... do I set base FP w/o the vac hooked up? So at 0psi its a true 58psi?
