5.3 Vacuum port required
Old 04-24-2008, 01:03 AM
Chizel's Avatar
Default 5.3 Vacuum port required
Well, I know I have seen it posted here before, but now when I need it I sure can't find it. What I am after, is a Vacuum port to put into the back of the intake on my 5.3. I assume that it must be where the stock vac line would run to the brake booster, as all I have in there right now is a hole. Does anyone have the GM part number for a plug to go in there to run a vac line off? Let me know if you do, thanks!
Old 04-24-2008, 04:31 AM
Moderator
91parkave's Avatar
you can use a brass fitting and and screw it into the plastic with JB weld on the threads
Old 11-23-2014, 09:20 PM
Mercier's Avatar
Here is the real answer..this kept popping up when I was searching for the answer to this so here is that answer to close the thread:
ACDelco 12559760
"GM Original Equipment Power Brake Booster Vacuum Hose Connector"
$7.50 with free shipping on Amazon.com. Also not too expensive at the dealership..maybe ~$12 if I recall correctly.
Old 11-24-2014, 01:18 AM
Mercier's Avatar
Novak also has a really nice metal version that makes this a 3/8 inch vac hose connection. $20 but it plugs right in. I am ordering one of these as well.
http://www.novak-adapt.com/catalog/e...gine_parts.htm
Old 11-25-2014, 10:55 PM
76larkman's Avatar
Smile
I found mine was broke gone or whatever so I got a brass bushing screwed it in then screwed in a barbed fitting put power brake hose on that. No problem.
Old 11-26-2014, 03:07 PM
Mercier's Avatar
That's a way to go also. I hope you don't break it off again because this time it wont break the brass but the intake itself. The nylon it's made of is pretty strong though.
I like the fact that it's a quick-connect kinda fitting so when I go to hydroboost I can just pull the nipple out and pop the factory plug back in with about 5 seconds of effort. Also, FYI to all, it is the same fitting on the 2000-ish intake I had on my LM7 and the 2010-ish intake that I put it into. Could have just swapped it over. Doh.
Quick Reply: 5.3 Vacuum port required
