dont have reverse.
Old 04-24-2008, 03:11 PM
LT4hotcam's Avatar
Default dont have reverse.
i put it in reverse and it wont go, so i had to put it in neutral and push it out of the parking space. then i put it in drive and it drives like normal and has all gears. Can anyone help me out.
Old 04-24-2008, 03:14 PM
WS SIKZ's Avatar
if its in reverse and you rev it high and it starts inching back , most likely its the reverse clutches check the trans oil and if its purplish brown most likely you need to get it rebuilt
Old 04-24-2008, 04:14 PM
LS1Tech Sponsor
performabuilt's Avatar
No reverse would be a mechanical issue like mentioned its it was sudden I have seen the LOW/REVERSE piston and the REVERSE INPUT drum piston crack and cause this. But your definatly gonna be rebuilding or replacing
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-24-2008, 04:47 PM
GT Griller's Avatar
U better take that **** back to fergusson or get ur money back and take it to Richard, u know he will do it right.
Old 04-24-2008, 05:01 PM
LT4hotcam's Avatar
Its allready at his shop.
Old 04-24-2008, 10:04 PM
GT Griller's Avatar
SUcks to hear chris...hope he fixes it tho.
Old 04-25-2008, 12:37 PM
LT4hotcam's Avatar
i kno and i was planing on going to the track this weekend and running it to.
Old 04-30-2008, 09:07 AM
LT4hotcam's Avatar
I found out what happened, the teeth broke in the shell, has that ever happenede to any one, i have to get a whole new shell.
Old 04-30-2008, 09:47 AM
LS1Tech Sponsor
Well if it was a built trans It should the beast shell with your setup , I have never seen a beast strip the teeth out. If it didn't have one thats what you should replace with, And why are you buying it I would think that would be under warranty. Or is it a labor only warranty no hard parts I have seen some written that way.
__________________
Call 888-744-6542
Old 04-30-2008, 10:02 AM
BlackZ28629's Avatar
interesting... my reverse is doing the same...rev high then pulls... I have a beast sun shell though..its prob. something we missed when putting the new input drum in...
Old 04-30-2008, 12:08 PM
LS1Tech Sponsor
Yes if you move at all in reverse even reved then its would not likely be th shell
__________________
Call 888-744-6542
Old 04-30-2008, 02:37 PM
GT Griller's Avatar
I agree.....if fergussen "built" u the tranny the sunshell should have been replaced....i think he gave u a stock rebuild with a shift kit.
Old 04-30-2008, 03:12 PM
LT4hotcam's Avatar
the sunshell was okay, thats what he thought had messed up the reverse. He showed me the sunshell, it was fine.
Old 04-30-2008, 11:50 PM
GT Griller's Avatar
sssssssssssssssss...so what was it fool?
Old 05-01-2008, 07:02 PM
LT4hotcam's Avatar
The teeth on the inside of the case were all the gears go, inside the tranny.
Old 05-01-2008, 08:32 PM
LS1Tech Sponsor
You mean the lugs on the inside of case where the low/center support goes completely stripped, WOW haven't seen that , I have seen then worn badly but broken all the way around though no.
__________________
Call 888-744-6542
Old 05-01-2008, 09:52 PM
GT Griller's Avatar
Damn that sucks.....ask Carlos tranny #4 did that on him....lol
Old 05-02-2008, 08:52 AM
LT4hotcam's Avatar
Yah thats what happened. It does suck
Old 05-02-2008, 04:48 PM
armyracer11's Avatar
I have seen that before, at the bottom where the sprag goes? It usaly means they didnt put the case saver (the little spring) in all the way or in at all.
Old 05-03-2008, 09:35 AM
LT4hotcam's Avatar
He went ahead and put the beast shell in there and took out the sun shell.
