ls3 wire harness for crate engine install
Old 04-24-2008, 03:48 PM
boxmonkeyracing's Avatar
Default ls3 wire harness for crate engine install
ok I've been looking at doing an crate LS3 swap into my 98 F-body. I' know I have a different pcm then the rest of the LS1 F-bodies out there. so I'm looking at just doing the whole ecu and harness swap. so has anyone delt with this harness?
LS376-480-Controller-Kit-19201327-P2221C242
I'm just looking for more info like what after market guages I can use and how difficult would it be to install in a 98 Z28 T56 Camaro?
Old 04-24-2008, 04:21 PM
bczee's Avatar
No able to really help you, but I have a question or concern...
It is in regard to being smog legal, if your care about that.. What are the smog / swap law there in NC.?.. if you swap the ECU out the 98' ECM for another one and they test for ODBII VIN information, you would fail..!?.. unless you were able to program your old VIN.
Just wondering if it is a problem to be concern with or how you are going to get around it ?
Old 04-24-2008, 04:26 PM
car's reg in TN. where I'm originally from. no emissions testing there. also Tech II can load a vin on the ecm.
Old 04-24-2008, 07:38 PM
jw33's Avatar
I've got the LS2 harness and it worked out great. Best deal out there by far right now at only around $800
Old 04-24-2008, 08:50 PM
how did you wire up the guages?
Old 04-24-2008, 10:47 PM
jw33's Avatar
My motor is in a mustang and I used all aftermarket gauges. The harness comes with a bulkhead connector that has temp output, oil pressure output, VSS, tach output and a bunch more. I just used the VSS and tach signals and the rest of the gauges had their own sensors. The harness even came with a male plug for the bulkhead connector so you just crimp the pins on your wires and slip them in the connector....Looks factory.
Old 04-24-2008, 11:50 PM
coolness. thanks. hopefully soon I can order my ls376/480hp and harness.
Old 04-25-2008, 10:58 AM
Project GatTagO's Avatar
Received 1,391 Likes on 879 Posts
When I checked a couple of months ago, this engine and harness was not shipping yet.
Andrew
Old 04-25-2008, 02:42 PM
poorhousenext's Avatar
Andrew
LS3 480HP came off BO and have been shipping since middle of March. I've had one in hand since then and I was number 26 on BO list. Don't know about GM harness as don't plan on using it.
Old 04-25-2008, 06:03 PM
That's good to know. Thanks for the update!
Andrew
Old 04-26-2008, 09:45 PM
where'd you get yours? crateenginedepot.com said it's on BO till june.
Old 06-06-2018, 08:20 AM
Tyler Lucas's Avatar
Default Ls3 swap
I’m doing a similar swap but a ls3 crate motor with pcm into a 99 trans am and I am am on wiring up the gauges, she drives almost perfect it’s now just inspection gauges and all that. But I would appreciate to know how you figured this out
Quick Reply: ls3 wire harness for crate engine install
