Coil pack rail question
Old 04-24-2008, 08:19 PM
TRlGGER's Avatar
Default Coil pack rail question
When you move the coil pack rail upward to do a sparkplug change, there is a cable behind it wrapped in shiny aluminum looking tape. What is that? and if you remove the coil pack completely what happens to that cable or wires?
Old 04-24-2008, 08:23 PM
wtomlinson's Avatar
i never moved anything when i changed my plugs. is this a common thing? try tracing the wire
Old 04-24-2008, 08:26 PM
99blancoSS's Avatar
sounds like your talking about the coil harness. You need it.
Old 04-24-2008, 08:42 PM
TRlGGER's Avatar
Im going to change my plugs but instead of just tilting the coil pack rail upward i was thinking by removing the whole coil pack rail i will give my self more space for spark plug 8 but when i looked behind the coil pack rail when i was trying it and noticed that wire or harness and was wondering if i remove the whole coil pack rail will that wire still hold on to the rail where i cant take it out of my way?
Old 04-24-2008, 08:47 PM
99blancoSS's Avatar
just unplug it and you can remove the whole coil pack and rail
Old 04-24-2008, 09:10 PM
TRlGGER's Avatar
thanks!
