Generation III Internal Engine - Oil Pump
transam0486
04-25-2008, 05:50 AM
what's the most economical upgrade for the shitty 1998 type?
gm part nmb: 17801830 "high volume ls pump" -$73
OR
gm part nmb: 12586665 "ls6 oil pump" -$102
is there that big of a difference between the 2?
LS1Z28_98
04-25-2008, 07:15 AM
Well, IMHO, spend the $145 and get a Melling Oil Pump. I''m a big believer in doing things once. I just did a cam and spring swap. I had no issues with my old 98 pump, but since the cover was off, 70,000 miles was time to do the pump and chain.
At idle at temp. I get 40 psi and under load I am over 60 psi.
An extra $50 is worth peace of mind
KingSumthn
04-25-2008, 07:39 AM
i have the ls6 and im getting great oil pressure with the vindicator cam...one of the biggest cams. if u only have 100 bucks it works great. but if u have more money to spend the best one u can get is usually the best way to go. that melling one sounds nice
allngn_c5
04-25-2008, 08:14 AM
I also have the LS6 and I get 40 at warm idle typically and WOT have seen 77psi.
tylerdj
04-25-2008, 08:26 AM
I used the ls6 and had good pressure and no issues.
SS101
04-25-2008, 10:28 AM
melling is the best choice but it will cost alittle more...i'll spend the extra coin for piece of mind tho
transam0486
04-25-2008, 11:34 PM
thanks guys
white99
04-26-2008, 12:00 AM
Melling +142358
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
