timing chain position (pic)
Old 04-25-2008, 10:21 PM
verano29's Avatar
Default timing chain position (pic)
98 corvette LS1. Is this correct? Is it possible to be this close and not have it on correct?
Old 04-25-2008, 10:32 PM
PREDATOR-Z's Avatar
Right on, that is perfect
Old 04-25-2008, 11:50 PM
LSX Mechanic
Damian's Avatar
Thats as good as it's gonna get brother.
Old 04-26-2008, 12:02 AM
verano29's Avatar
Cool thanks!
Old 04-26-2008, 06:58 AM
vettenuts's Avatar
Did you loctite your cam bolts?
Old 04-26-2008, 07:42 AM
Hell'sChariot's Avatar
Lookin good.
Old 04-26-2008, 08:50 AM
verano29's Avatar
I did loctite the cam bolts but I didn't go overboard on the stuff. How much of the stuff should I use? I didn't want the lotite to squish out of the bolts and find its way into the bearing and loctite the bearing.
Old 04-26-2008, 09:01 AM
vettenuts's Avatar
Kewl.
Old 04-26-2008, 09:09 AM
DaveX's Avatar
Alignment looks good. It would have to be one tooth off not to be right, so just imagine how it would look if one of the dots was on the next tooth over.
I used just a small amount of blue loctite on the cam bolts. I use it on several things, just to be safe.
Also just a tip if your not already aware. When you put the oil pump back on, slide it on and just start the mounting bolts but leave them loose. Then install the pickup tube with a new o-ring and tighten it down completely before tightening the oil pump mounting bolts. If you tighten the pump down first and then install the pickup tube, you will most likely damage the o-ring and be hating life later when you have oil pressure problems.
