carb and a 4L60E
It needs to be converted to Full Manual.
Then, you'll need to add a Converter Lock Up toggle switch and Manually control lock up.
If you need help with this give me a shout.
g
g
sounds like it would be pretty badass that way though is that by changing the valve body? how does the switch work? and about how much that trans needs a rebuild anyway
