lt-1 Edit trans programming
Does anyone know how to stop a 4l60e from going into limp mode with a high stall converter using lt-1 edit? The car is hitting what they call "Stall wall" because the computer is picking the stall as a slippage problem and throwing the trans into limp mode and it wont shift out of first unless you lift.I was told I can fix this with my LT-1 edit ,I'm just not sure how.Any help would be greatly appreciated,Thanks, Shaun
It's an ATI 10 inch with lockup. I don't exactly know the Stahl but it's pretty loose. It works tremendously when the car will shift,but i haven't been able to make a real pass with it because of this.Other than that the converter works great.
