What is a safe boost # on 6.0L iron block?
Old 04-26-2008, 09:36 AM
SLID's Avatar
Default What is a safe boost # on 6.0L iron block?
I am putting a new set of ET heads on my 408 with a F1R Procharger. What would be a safe boost # I could run without lifting the heads. Is 15psi to much?
Old 04-26-2008, 09:37 AM
El_Diablo's Avatar
As long as you have some good head gaskets and your studs are torqued down it'll chuckle at 15psi.
Old 04-26-2008, 03:08 PM
tomz28's Avatar
as long as its under 20 you should be good
