Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Who to screw the power stirring pump?
Old 04-26-2008, 02:54 PM
James911's Avatar
Default Who to screw the power stirring pump?
Hi,
I bought an disassembled Impala (350 cui, 1970), therefore I have some problems to put it together.
Right now I struggle withe the power stirring pump.
I put the bolt through the water pump hole (see pic)
http://i303.photobucket.com/albums/n...rstirring3.jpg
But where do I have to fix the following part (pics) to adjust the belt at the engine?
http://i303.photobucket.com/albums/n...rstirring2.jpg
http://i303.photobucket.com/albums/n...rstirring1.jpg
Do have to fix it with a bolt of the exhaust manifold, and where else?
Thanks for help.
James
Old 04-26-2008, 03:00 PM
9000th01ss's Avatar
That looks like what I used to use. The bracket bolts to the front exhaust manifold bolt, the welded nut on it should go to the power steering pump bracket with the slot.
If you use headers you need to use a spacer on the exhaust.
Old 04-26-2008, 03:09 PM
James911's Avatar
Thanks,
But like this I fix the bolt close to the welded nut, but where do I have to fix the second screw for the second hole on the other site?
Old 04-26-2008, 04:34 PM
9000th01ss's Avatar
link not working.
Old 04-27-2008, 05:23 AM
James911's Avatar
link not working.
now it should work
Old 04-27-2008, 09:24 AM
9000th01ss's Avatar
Not sure what that bracket is for, the ones I've used always been a part of the ac bracket.
